TwinTurbo.NET: Nissan 300ZX forum - #6 cyl not firing ONLY on idle
Subject #6 cyl not firing ONLY on idle
Posted by BOOZTD 3 on May 15, 2011 at 5:13 PM
  This message has been viewed 168 times.
Message Guys
I've been chasing this issue for several days now (and not 10-15 minute intervals either) and its really got me scratching my head
The engine is noticeably rough at idle for starters. Only at idle with the number 6 cylinder not fire. I disconnect the coil pack and there is no noticeable change in idle. Disconnecting every other coil results in an expected condition.
I suspected the fuel injector at first, so I got to looking at it, and noticed the physical connector on the injector was somewhat cracked. I know how finicky these injectors can be, so I replaced it.....only to yield the same mis-fire condition.
I went on to throw a 3rd known good fuel injector, and we're still having the same problem
I do notice that when I hold anything over 1500rpm or so, the engine smooths out, and I can disconnect the coil at that RPM and you can feel the engine start to mis-fire.
I've checked the compression and its OK, and I also swapped in a 2nd known good coil.
At this point I have not swapped the PTU, however I am doubting thats the issue.
The wiring harness is only about a year old and the car is rarely driven. I did take this harness from one I had to cut the injector connectors off of for an Border 850 kit, however I reverted back to the early style connectors. I dont suspect the wiring could be the issue as I soldered the connections.
Anyone ever come across this issue before?
