TwinTurbo.NET: Nissan 300ZX forum - It's a lifter or VTC.
Subject It's a lifter or VTC.
Posted by Draker (Eugene, OR) on May 15, 2011 at 3:46 PM
  This message has been viewed 139 times.
In Reply To Re: I'm with Draker at this point posted by jaidieray on May 15, 2011 at 03:35 PM
Message Probably can't hold oil and is leaking down or it's not getting oil to it. Check your oil level.
Burp the coolant system with the heater on full.
I would ensure your oil level is correct, and run it for a bit. See if it gets better. If not you might need to swap the lifter out. It's not a knock though, so cross it off your list.
