TwinTurbo.NET: Nissan 300ZX forum - Is your oil pan dented? That would cause low oil pressure
Subject Is your oil pan dented? That would cause low oil pressure
Posted by J_Wright on May 15, 2011 at 1:42 PM
  This message has been viewed 241 times.
In Reply To Re: First, take a step back and relax. posted by jaidieray on May 15, 2011 at 01:06 PM
Message which could lead to rod knock. And no, a spun rod bearing would not cause idle to fluctuate. A spun rod bearing would cause bits of metal to be passed through your oil system, destroying everything in your motor.
Your erratic idle is possibly from a dirty electrical connector, causing something like your Idle Air Control Valve to not receive the signal the ECU is sending it.
