TwinTurbo.NET: Nissan 300ZX forum - Re: First, take a step back and relax.
Subject Re: First, take a step back and relax.
Posted by jaidieray on May 15, 2011 at 1:06 PM
  This message has been viewed 169 times.
In Reply To First, take a step back and relax. posted by Draker (Eugene, OR) on May 15, 2011 at 12:13 PM
Message I had the crank micro polished and then I measured the journals. The tolerance for main bearing is .0011-.0022 I ordered oem bearings to put it at .0015 The connecting rod clearance is .0011-.0019 and I ordered oem bearings to put it at .0015 I ordered a new oil pickup tube with the correct newer style gasket(not an o-ring). My oil pump has less than 5k miles on it.
Ive cranked the car probably 8 times since I rebuilt it last september because ive been troubleshooting why ive been randomly dropping cylinders (bad old style ptu)so its ran maybe 5-10 minutes total until today so i dont think its an assembly lube problem. I used redline assembly lube liberally. My oem oil pressure gauge was reading just past the 1st mark.
Would a spun rod bearing cause the rpm's to fluctuate in neutral when previously it was steady at 900? I only have a regular stethoscope. Do you just crank it and place it on the side of the block?
90na2tt swap KH2 charcoal 5spd
93tt 5spd AH3=sold 90na auto EJO=sold
06 spec v=sold 95 awd talon=sold
