TwinTurbo.NET: Nissan 300ZX forum - Re: middle white wire, all you need to know for adjustment
Subject Re: middle white wire, all you need to know for adjustment
Posted by enthuZiast on May 14, 2011 at 10:11 AM
  This message has been viewed 114 times.
In Reply To middle white wire, all you need to know for adjustment (n/m) posted by ZiNnYc on May 13, 2011 at 09:47 PM
Message It seems that the FAQ and FSM have different methods of adjusting.
Where I have left off is, the throttle position sensor is plugged together and wire stuck into the middle white wire and throttle position switch is disconnected. Do I turn the ignition to ON position? Then ground the stuck-in wire and turn the TPS switch so I get 0.4V-.5V? Is it critical that the engine needs to be warm?
