| Subject |
ECU question, I currently have an AshSpec ECU with |
| Posted by |
ChrisZTT(Sacto, CA) on May 11, 2011 at 10:33 PM |
This message has been viewed 136 times. |
| Message |
federal codes, Manual, TT, 370, single pop and I switched in a JWT with same setup and as soon as I turn the key on the fan kicks on. The car was not hot, it had been sitting for hours. Any idea what could cause that? I switched the AshSpec back in and the fan is back to normal. Not sure if this is important but this was a TT swap and I had put in the TT electric fan and had to splice the TT connector into the NA harness so only one speed of the two speed wires is connected at the fan. The other speed wire was obviously not there on the NA harness. On a side not, if this is the problem does anyone know where to run the second fan speed wire too?\ TIA, Chris.
| Follow Ups |
Post a Followup |
