TwinTurbo.NET: Nissan 300ZX forum - Ya thats the weird part. There is suppose to be a 4mm
Subject Ya thats the weird part. There is suppose to be a 4mm
Posted by 5280Z_nightstalker on May 11, 2011 at 10:14 PM
  This message has been viewed 137 times.
In Reply To But isn't the tensioner too tight? posted by Serg300zx on May 11, 2011 at 10:10 PM
Message gap when you install the belt then you remove the bolt to let the tensioner put tension on the belt to keep it tight. If anything the gap should increase over time not shrink so that is why everyone THOUGHT the bolt was still in place because the gap should have not shrunk to the point of almost fully closed
"Do you guys put the key in "balls down", or up?" -BobbyT 10:28:19 03/06/09
tt.net
