TwinTurbo.NET: Nissan 300ZX forum - Re: So Nube turbo question here...
Subject Re: So Nube turbo question here...
Posted by supermario680 on May 10, 2011 at 8:02 PM
  This message has been viewed 114 times.
In Reply To So Nube turbo question here... posted by Red Hawk (CO) on May 10, 2011 at 11:24 AM
Message not really, basically you can't run anything LOWER than Wastegate spring pressure...
You can run HIGHER Pressure by installing a boost controller which "pinches" or "bleeds off" extra pressure.
So when you turbo's are actually making 15 psi, 4 psi of that is either bled off or restricted so the wastgates "only see" 11 psi and then open.
