| Subject |
First, find the relay, per ZiNnYc's instructions, then pull |
| Posted by |
zellamay on May 10, 2011 at 2:10 PM |
This message has been viewed 228 times. |
| In Reply To |
Re: The relay is green, and is perpendicular to the ground. posted by z14phunn on May 10, 2011 at 09:35 AM |
| Message |
it out. There are 2 big prongs and 2 little prongs. In the car, there are 2 big slots and 2 little slots that match. Make a jumper wire for the 2 big slots in the car. You have now bypassed the relay. Turn on the ignition key. If you hear the fuel buzzing, then the relay was bad. If you don't, then the problem is someplace else. ... From your previous post, Did you run 12v directly to the fuel pump, to see whether it is actually working? ... P.S: When responding, if you erase the previous header and verbiage, we don't have to read the same stuff several times.
| Follow Ups |
Post a Followup |
