TwinTurbo.NET: Nissan 300ZX forum - Swap out MAFs and run a boost and vacuum leak test
Subject Swap out MAFs and run a boost and vacuum leak test
Posted by ZiNnYc on May 10, 2011 at 10:03 AM
  This message has been viewed 287 times.
In Reply To Power cut out and bogging down posted by rojoloco (San Diego) on May 10, 2011 at 07:39 AM
Message What do you mean by your TPS is clean? That you cleaned the connectors, or that you opened it up and refreshed it? Ohm it out, set it and reset just to be safe.
You painted your plenum, did you screw with the linkage/TBs? Do they open together?
What's your PTU and subharness look like? Assuming you're chipped for your new mods accordingly?
Codes? What's your timing look like?
