TwinTurbo.NET: Nissan 300ZX forum - Re: The relay is green, and is perpendicular to the ground.
Subject Re: The relay is green, and is perpendicular to the ground.
Posted by z14phunn on May 09, 2011 at 7:00 PM
  This message has been viewed 180 times.
In Reply To The relay is green, and is perpendicular to the ground. posted by ZiNnYc on May 09, 2011 at 05:51 PM
Message :If you remove the driver side kick panel you cant miss it, it is closest to the door sills.
:Are there any other issues other than the alleged fuel pump one?
No once it runs again I have a lot of questions as far as jwt and mods already done but I need to stay focused on this like I said it has been a perfect daily driver aside from this oh and now that I think about it I was going to take to a local shop in vince,ca. to have my front end looked at I believe my rack and pinion bushings need to be replaced replaced but thats irrelevant to this . I just found it strange that as I was crossing railroad tracks it would die and it would be a relay but with the way my luck has beenI would be grateful if it is as simple as a relay
