TwinTurbo.NET: Nissan 300ZX forum - I remember your post. I can't help much, because I don't
zellamay
on May 09, 2011 at 3:36 PM
91 tt w/ no power to fuel pump
posted by z14phunn
on May 09, 2011 at 01:37 PM
know where all those fuses and relays are. With some effort, you should be able to find out. I have one suggestion. Run a live wire to the fuel pump, to make sure it actually works when it has power.
z14phunn
13:37:12 05/09/11
I remember your post. I can't help much, because I don't -
zellamay
15:36:42 05/09/11
The relay is green, and is perpendicular to the ground.
ZiNnYc
17:51:49 05/09/11
Re: The relay is green, and is perpendicular to the ground.
z14phunn
19:00:58 05/09/11
Re: Re: The relay is green, and is perpendicular to the ground. (n/m)
z14phunn
19:02:08 05/09/11
z14phunn
09:35:52 05/10/11
First, find the relay, per ZiNnYc's instructions, then pull
zellamay
14:10:23 05/10/11
Re: First, find the relay, per ZiNnYc's instructions, then pull
z14phunn
14:20:32 05/10/11
z14phunn
10:07:24 05/10/11
