TwinTurbo.NET: Nissan 300ZX forum - Re: Replacing 1 versus 6 injectors (n/m)
johnbsz
on May 07, 2011 at 5:59 AM
Replaced 1 versus 6 injectors
posted by johnbsz
on May 07, 2011 at 05:57 AM
johnbsz
05:57:51 05/07/11
Re: Replacing 1 versus 6 injectors (n/m) -
johnbsz
05:59:34 05/07/11
Theres no surefire way to know if theyll fail
ZiNnYc
12:35:45 05/07/11
I think you should grind the plenum while it's off, for
zellamay
15:37:11 05/07/11
2nd. It's a very good idea to grind it while it's off. Then
doug8867
15:56:12 05/07/11
If all original -- I'd plan on others failing in the not
jzack
20:42:06 05/07/11
78% Chance the Other Injectors Will Fail!
OverZealous (CT)
01:28:45 05/08/11
Re: Replaced 1 versus 6 injectors (n/m)
johnbsz
09:08:50 05/08/11
johnbsz
09:12:26 05/08/11
Dremel the plenum anyway. What if you have a fuel leak
zellamay
09:46:50 05/08/11
