| Message |
:and my speedometer and coolant temperature might not be working. this weekend I replaced my power steering pump and when i was taking it for its test drive I noticed that 3 of the gauges were not working. :first thing i did was check the oil pressure sending unit, it read 36 ohms at idle. so I dont think its that. I checked every fuse, they all look ok, but I didn't meter them out :I have a check engine light on, the codes are 34 and 51 Detonation sensor and Injector circuit, im cleaning my injector connectors this weekend, they are dirty :any ideas? :is 36 ohms a good reading for the oil switch? I figured it out, i was a loose connector in the alternator to engine harness, i knocked out near the power steering pump
