TwinTurbo.NET: Nissan 300ZX forum - from what I've read
Subject from what I've read
Posted by Shiers69 on May 05, 2011 at 12:13 PM
  This message has been viewed 130 times.
In Reply To Re: Do It posted by zxrider45 on May 05, 2011 at 10:37 AM
Message **6-8 psi on a NA engine is totally do-able alhough the factory NA engine is already running very high compression. You might want to drop the compression slightly with a thicker head gasket. Also, I believe the stock NA injectors are pretty close to their flow limit already so larger ones might be needed. You can probably get a set of used factory TT injectors for fairly cheap though.
Are you thinking about modifying the intake manifold for a single input?
When all is said and done, are you planing on doing the tuning yourself? with what?
You might have shitty turbo lag but for a few hundred it might be a fun little project.
**I'm no expert on this
