TwinTurbo.NET: Nissan 300ZX forum - After removing the flywheel/clutch, spray and clean the area
Subject After removing the flywheel/clutch, spray and clean the area
Posted by PiotrC70 on May 04, 2011 at 8:28 AM
  This message has been viewed 185 times.
In Reply To First transmission pull! posted by Coldfusown on May 04, 2011 at 04:04 AM
Message down with brake clean let it sit for a while and you should likely see the leaks. Down side of doing this is that you could have replaced the cheap rear main by then. Also, below the rear main is a half moon gasket that sometimes leaks.
1993 TT. R.I.P. 09.15.2010
