TwinTurbo.NET: Nissan 300ZX forum - Re: What is next after taking out radiator to pull engine out
Subject Re: What is next after taking out radiator to pull engine out
Posted by parrotheadz on May 04, 2011 at 4:48 PM
  This message has been viewed 110 times.
In Reply To What is next after taking out radiator to pull engine out posted by newttcar on May 03, 2011 at 12:52 PM
Message buy gallon and quart size freezer bags and a black sharpie. This will help you keep all the bolts and small items in order and if you have the room lay things out in an order that you remove them. I have pulled my motor four times and these steps help. Also if your changing out your main harness make a good diagram for the pin out of the smaller connector that you have to remove to fit it through the firewall. and there are two light green wires that are almost the same so use the sharpie to mark one of them so when you go to put it back together you will get it right. Hope this helps and you really should buy a service manual.
