TwinTurbo.NET: Nissan 300ZX forum - The oil seal at the far end near end the cover, right?
Subject The oil seal at the far end near end the cover, right?
Posted by evan_aggie on May 02, 2011 at 11:26 AM
  This message has been viewed 104 times.
In Reply To Use a heat gun - this will soften the oil seal posted by Onyxblue on May 02, 2011 at 11:16 AM
Message I just want to make sure we're on the same page. So, I just need to heat the aluminum housing around where the oil seal sits, or point the gun inside the housing itself? I guess I could try both. I'm never quite sure how much to attempt to heat something up via a heat gun like that.
At least with the push-lock fuel hose the ends actually start smoking and then I knew it was hot enough.
