TwinTurbo.NET: Nissan 300ZX forum - The on thing in question is the crank and that pic is blurry
Subject The on thing in question is the crank and that pic is blurry
Posted by BoneZ on May 01, 2011 at 7:06 PM
  This message has been viewed 324 times.
In Reply To Re: 300zx crankshaft timing question. posted by Revolt on May 01, 2011 at 03:08 PM
There is a white line on the timing belt down near the crankshaft. It needs to be lined up with the dimple on the sprocket same as the others with their respective marks.
Do you have an FSM? If not use the online one, it has the info you need and the counts in between points.
-___________________________________________________________-
