TwinTurbo.NET: Nissan 300ZX forum - Re: Sort of
Subject Re: Sort of
Posted by Revolt on April 28, 2011 at 3:10 PM
  This message has been viewed 401 times.
In Reply To Sort of posted by Stadsport (PHX) on April 28, 2011 at 03:02 PM
Message well.. the marks on the cam gears line up with the marks on the timing belt but you can see the crank is about 1'' from lining up with the mark on the oil pump. So since these are approximate.. do i need to remove the belt and turn the crank shaft or will everything be ok as it is.
