| So i removed my FF to inspect my ICs due to my boost leak.. And turned out that i have a hole in the PS IC, i replaced that and while i was there deleted the carbon canister.. The issue here is that i didnt have the bottom connection where the new connection of the fuel line should be done... However in Robo's site he stated that this shouldn't be a problem.. So i plugged the nipple under the PS TB, the nipple on the balance tube and the nipple on the intake pipe (the one that could be seen when the turn signal is removed..) everything else in uncapped.. I should be okay with this right ?
