TwinTurbo.NET: Nissan 300ZX forum - PB Blaster and a tap on top with flat head usually does it.
Subject PB Blaster and a tap on top with flat head usually does it.
Posted by Milo (SATX) on April 27, 2011 at 1:10 PM
  This message has been viewed 208 times.
In Reply To steering u-joint : is it okay to hammer off? posted by evan_aggie on April 26, 2011 at 01:14 PM
Message Make sure you release the nut that holds the unit to the spline.
Sometimes you will have to unbolt the rack to adjust it forward to get it to slide out a bit.
Keep at it. Should come out easily. You can always lightly put some heat to it and apply PB again.
