Check the AC control pod again. Do you have a friend close by with a Z, switch it out, to test. If your car has the digital A/C controls, the amplifier is under the dash. You might of pulled the wires. I have seen stranger things happen. But most likely it can be the pod, that is not opening the flap to divert from hot to cold.
