One correction to make as well the post before I accidently switched the numbers around , but if your reading the posts you probably figured that out. So I whipped out the dremel and ended up replacing two faulty injectors last night ,fired it up and wow does she run great. Thanks for the all but be it repeditive and obviously needed advice ZiNnYc.
