TwinTurbo.NET: Nissan 300ZX forum - Fuel pressure rises with boost pressure...you probably
Wright (Ca)
on April 21, 2011 at 12:38 PM
also, i only started smelling fuel when I activated my BC??
posted by blackomega
on April 20, 2011 at 08:16 PM
exposed a loose fuel clamp by raising the boost. Find that leak!
Formerly: ZEVAN (Ca), Evan3zx(ca)
Multiple small issues...
blackomega
15:20:29 04/20/11
There are several fuel hoses under the plenum you can't see.
Draker (Eugene, OR)
18:36:52 04/20/11
any way to verify them without pulling the plenum?
blackomega
20:12:41 04/20/11
blackomega
20:16:11 04/20/11
Fuel pressure rises with boost pressure...you probably -
Wright (Ca)
12:38:17 04/21/11
Any reliable way to test besides
blackomega
14:32:37 04/21/11
Just tighten all of them. It will be obvious if one is
Wright (Ca)
15:17:36 04/21/11
can I easily access all of them? (n/m)
blackomega
17:06:23 04/21/11
Easily? Well that is debatable. FWIW, I can access them all. (n/m)
Wright (Ca)
17:32:38 04/21/11
There's really just 1 fuel hose under the plenum and
jzack
22:36:05 04/20/11
I'm guessing you cant service this line with the plenum on? (n/m)
blackomega
14:01:11 04/21/11
SURE YOU CAN!!!! Go into the AutoFAQ section of this
jzack
22:56:39 04/21/11
Another small issue
blackomega
14:08:04 04/21/11
Translator? Doubt that has anything to do with the issue.
Wright (Ca)
15:14:23 04/21/11
I'm saying the translator is what keeps the car running,
blackomega
17:02:46 04/21/11
I mean no offense but I think you are giving the translator
Wright (Ca)
14:31:37 04/22/11
Check your brake booster in addition to the above (n/m)
ZiNnYc
17:39:13 04/21/11
Hood: Maybe latch needs adjusting, but first make sure
Gordo 93TT Daytona
17:59:19 04/21/11
