TwinTurbo.NET: Nissan 300ZX forum - Oil leak. Need help!!!
Subject Oil leak. Need help!!!
Posted by ba11erz on April 20, 2011 at 11:57 AM
  This message has been viewed 239 times.
Message Well, after months of rebuilding, I noticed an oil leak shortly after I started her up.
There was a puddle directly under the oil pan, and I traced down the source (with a bright halo flash light) and determined it's the braided supply hose for LH turbo.
The motor is already in, and I sure don't want to pull it out.
It was painful having to do all this work solo.
Q: Is there a trick for accessing and tightening the LH Turbo oil supply banjo bolt attached to the block? (obviously w/o having to pull the motor)
Any help on this would be a lifesaver.
