Mine leaked when it was cold and the OEM replacement eliminated any issue.
Oil only enters the line when prx gets too high via a check valve on the oil filter bracket. At startup or hard driving conditions it will leak and you'll see it visibly wet on the steering rack clamp. There is little oil prx in the line during normal use.
