TwinTurbo.NET: Nissan 300ZX forum - The two shifter boots, upper and lower.
Subject The two shifter boots, upper and lower.
Posted by SilverTwin(OH) on April 17, 2011 at 11:56 AM
  This message has been viewed 136 times.
In Reply To Re: Both rubber shifter boots in place? posted by plower on April 17, 2011 at 08:24 AM
Message They help greatly in keeping the trans noise out, if they are not in place or properly secured, you will get high levels of trans noise like you are describing.
If you are running an aftermarket short shifter, the oem lower dust boot does not fit properly without being modified, common problem.
I would recommend pulling the center console to inspect them, only takes 5-10 minutes.
'91 TT
Stage ??
ZROC -The Z and Roadster Club of Ohio
