TwinTurbo.NET: Nissan 300ZX forum - Re: Both rubber shifter boots in place?
plower
on April 17, 2011 at 8:24 AM
posted by SilverTwin(OH)
on April 17, 2011 at 07:10 AM
Urethane mounts but not the issue, wheel bearings are fine, rubber boots? What do you mean? It works fine it is just that you hear the gears meshing especially under light loads in higher gears.
Transmittion gear noise
plower
13:50:35 04/16/11
do you have a solid or urethane trans mount? (n/m)
Shiers69
15:27:24 04/16/11
It might be a wheel bearing going out
sdhsbaseball
18:08:00 04/16/11
Mine is the same way.
Roundabout136
19:08:51 04/16/11
SilverTwin(OH)
07:10:47 04/17/11
Re: Both rubber shifter boots in place? -
plower
08:24:15 04/17/11
Are you running a short shifter? (n/m)
Roundabout136
08:33:47 04/17/11
The two shifter boots, upper and lower.
SilverTwin(OH)
11:56:17 04/17/11
