TwinTurbo.NET: Nissan 300ZX forum - Can you hear the Fuel pump kick on.
Subject Can you hear the Fuel pump kick on.
Posted by Sleeper_TTZ(SeKy) on April 11, 2011 at 3:29 AM
  This message has been viewed 153 times.
In Reply To Just got a Slicktop Z, can't get it to run posted by Imissmyz on April 10, 2011 at 01:03 AM
Message I was driving down I-75 on my way to drill, when the Z just died. Pulled over and tried a few things. Spark was good, No codes, etc. I could hear the pump prime but when I pulled the fuel line It had pressure and seemed good. But when I cranked it it wasn't flowing. Cycled the key and it would prime, and again not flow. Don't ask why I did it that way. I was on the side of the interstate. I switch the Fuel pump controller out and it started right up.
Now on to a better way to check. Get a inline fuel pressure gauge, Install it, Check the fp before start up, and while cranking. If it falls while trying to start it your in the same boat I was most likely. If it never gets up to spec then it could be Pump and FPC.
My 2cents
