TwinTurbo.NET: Nissan 300ZX forum - Re: flywheel dowel pins too tight?
Subject Re: flywheel dowel pins too tight?
Posted by 90GoldZ on April 10, 2011 at 9:18 PM
  This message has been viewed 212 times.
In Reply To flywheel dowel pins too tight? posted by idslave on April 10, 2011 at 08:02 PM
Message Is the pressure plate in the correct position?
Let it loose and turn the plate and see if all of the dowels line up with the holes on the pressure plate.
there should be only ONE way that the pressure plate lines up with all three dowels.
