| Message |
Check the CAS, my Z would only start for a second or two then cutoff. Turns out that the CAS was only sending out signal to the injectors at very low speed, when the motor finally saw ~1k rpm's, the injectors stopped firing, and the engine chut off. No ECU code was thrown. I ended up replacing it and my baby lived again. :)
