TwinTurbo.NET: Nissan 300ZX forum - Most likely oil pressure sender.
Subject Most likely oil pressure sender.
Posted by Under_Powered on April 10, 2011 at 8:33 PM
  This message has been viewed 124 times.
In Reply To HELP oil pressure gets very low posted by herewegosteelers on April 10, 2011 at 08:06 PM
Message Oil pressure itself is probably fine. You might need to replace the sending unit located on the oil filter tree, very common problem. There is a writeup in FAQ.
Wide open until you see God, then brake.
