So today i went out to work on the car, sense it probably was near 70 today i opened up the garage doors. Sense the garage was cold and it was super humid outside moisture built up on everything. I have my valve covers off and i looked at them and i got surface rust on the cam lobs cause of the moisture. I wiped them down to remove the water. Will this be ok? Will it just "grind" off when i start the motor, which will be this week sometime.
Surface rust on cams - TK3Z32(Wi)15:38:20 04/10/11
