TwinTurbo.NET: Nissan 300ZX forum - Oh boy -- let's hope the pinched o-ring is the only
Subject Oh boy -- let's hope the pinched o-ring is the only
Posted by jzack on April 08, 2011 at 10:33 PM
  This message has been viewed 85 times.
In Reply To gas in the cylinder and oil issue update posted by AcesZ on April 08, 2011 at 09:47 PM
Message damage? You'll need to pull the upper plenum to get to the fuel rail & injectors. Before doing all that -- I'd get the gas out of the engine and then try running a compression test on all cylinders. Best to verify this before doing a lot more work.
FYI - A turkey baster and a length of clear hosing fitted over the end is another way to gas out of the cylinders.
