| Message |
: I am going to assume that you skipped the part where you installed new injectors and unwittingly bungled the installation, pinching the o-ring. You get to do it all over again, NEW o-rings, incredible amounts of lube. DO NOT try to start it again. :REMOVE the gas from the cylinders NOW, get a hose and suck it out, or buy the hand-suction unit from a parts store. :The longer the fuel sits in there, the more likely you are to wash out the rings and have to replace them. :Go quickly, report back later.
