TwinTurbo.NET: Nissan 300ZX forum - Some or all of you injector lower o-rings are pinched
Subject Some or all of you injector lower o-rings are pinched
Posted by jzack on April 08, 2011 at 7:44 PM
  This message has been viewed 86 times.
In Reply To cylinders full of gas and gas in the oil posted by AcesZ on April 08, 2011 at 07:12 PM
Message and gas is leaking from them (under pressure) into block. Do not crank the engine until you get this fixed -- you may have already damaged the engine (ie., hydrolocked)...
Remove the fuel rail (still connected) to gas and wires and then turn the key - looking to see which injector is leaking out the bottom. Could also be an injector issue too - but more likely a leaky o-ring.
