TwinTurbo.NET: Nissan 300ZX forum - Bumping the starter is the best method. Put a piece of
zellamay
on April 07, 2011 at 9:03 PM
Crank Pulley bolt removal..
posted by Havoc300 (Chicago)
on April 07, 2011 at 02:05 PM
plywood behind the radiator to protect it, in case the wrench comes off.
Havoc300 (Chicago)
14:05:12 04/07/11
Lefty loosie baby! (n/m)
BoneZ
14:08:48 04/07/11
Thanks! 3 days & I'm still trying. No impact wrench. (n/m)
Havoc300 (Chicago)
14:24:50 04/07/11
breaker bar? (n/m)
BoneZ
14:51:29 04/07/11
Use a long pipe or breaker bar..
KongZTT GT28RS MD
14:51:42 04/07/11
I thought I was the only one to try that (n/m)
ZiNnYc
17:50:28 04/07/11
we "GTFO'ers" think alike :) (n/m)
KongZTT GT28RS MD
19:13:44 04/07/11
hei. crank pulley bolt...GTFO (n/m)
ZiNnYc
21:45:54 04/07/11
I just removed mine last night. I spraying penetrating lube
Samuel (Dallas)
15:59:09 04/07/11
Hey Samuel... Check Email. (n/m)
Havoc300 (Chicago)
16:38:25 04/07/11
I would use a 1/2" drive ratchet on it..
KongZTT GT28RS MD
19:17:07 04/07/11
Fuel pump relay out of course! (n/m)
BoneZ
20:25:03 04/07/11
yep. or just disconnect PTU or CAS
KongZTT GT28RS MD
20:47:16 04/07/11
Yeah, wouldn't want to see the "I tried this and..." post (n/m)
BoneZ
21:51:01 04/07/11
Bumping the starter is the best method. Put a piece of -
zellamay
21:03:21 04/07/11
Worked like a champ. Thanks Guys!! Now.....
Havoc300 (Chicago)
10:20:22 04/08/11
The key on the crank and pulley will keep it from turning. (n/m)
Woody75 (Denver)
11:48:30 04/08/11
Need to do this on my Automatic trans car. How to tighten? (n/m)
not4resaleZ
12:20:33 04/08/11
Should be able to do in park. (n/m)
KongZTT GT28RS MD
14:19:36 04/08/11
Use E-brake too (n/m)
KongZTT GT28RS MD
14:20:34 04/08/11
I always hate to load the trans in park. I may remove the
not4resaleZ
14:28:29 04/08/11
Guess there is also the "Belt Wrap" method. (n/m)
not4resaleZ
14:33:22 04/08/11
You aren't putting THAT much stress on the trans..
KongZTT GT28RS MD
15:07:19 04/08/11
Which I don't do. I use the parking brake for that.
not4resaleZ
16:30:03 04/08/11
put them on the ground :)..
KongZTT GT28RS MD
19:33:32 04/08/11
no...you'll just spin the torque converter (n/m)
aliaZ
06:48:50 04/10/11
Put car in 5th gear.. (n/m)
KongZTT GT28RS MD
14:19:21 04/08/11
oh yea.. and use E-brake. (n/m)
KongZTT GT28RS MD
14:20:12 04/08/11
How is the bolt tightened on the Auto tranny? (n/m)
Havoc300 (Chicago)
15:49:50 04/08/11
I just answered this above.. use your ebrake..
KongZTT GT28RS MD
16:29:21 04/08/11
Won't work, The torque converter slips. (n/m)
Fast300
22:54:34 04/08/11
If an auto tranny (and tranny is attached) -- remove
jzack
19:40:16 04/08/11
Just use the e brake.. why go through all that? (n/m)
KongZTT GT28RS MD
19:48:46 04/08/11
Because it won't work the torque converter will still slip.
Fast300
22:50:23 04/08/11
I didn't even think of that.. I don't own an auto..
KongZTT GT28RS MD
13:34:23 04/09/11
