TwinTurbo.NET: Nissan 300ZX forum - NA Z32 Running Rich. Possibly injector related.
Subject NA Z32 Running Rich. Possibly injector related.
Posted by mcavopol on April 03, 2011 at 9:21 PM
  This message has been viewed 574 times.
Message Here's the deal. Today I changed the passenger middle injector. Didn't remove the plenum, just got in there and popped the old out, and new in.
Well... by new I mean an old injector off a donor Z that I've purchased. Now the new(ish) injector that I installed tests (to the best of my knowledge) good. It reads 12.3 Ohms when I test the resistance.
After I first started the car after replacing it everything was running great, but after a little while she started running rich. Really rich. Backfiring every time I shift or rev at idle.
What is causing it to run so rich? Is the injector possibly bad? Also is there a way to tell which bank is running rich, so that I can determine if it is the same back as the injector replaced?
Another thing i've noticed, is that the car takes a while to start. I've never had issues starting the Z, and it's alway just cranked in less than a second. Now it takes maybe 20 seconds of sitting on the starter before she catches.
