TwinTurbo.NET: Nissan 300ZX forum - Yep - likely the injector. Pull the injector connector
Subject Yep - likely the injector. Pull the injector connector
Posted by jzack on April 02, 2011 at 11:48 PM
  This message has been viewed 119 times.
In Reply To Rough idle posted by huey24nissan(NC) on April 02, 2011 at 09:42 PM
Message plug, set meter to resistance setting, lowest resistance setting (x1 if you can set that?), apply meter test leads to the 2 terminals recessed in the injector's connector housing and read the meter. Should be between 10 and 14 ohms.
Hardest part of this job will be getting the wiring connector removed from the injector -- trying not to drop the clip (pin) that has to be removed. I use a dental pick type too and some needled nosed pliers to pull if off....
