TwinTurbo.NET: Nissan 300ZX forum - Plenum pull ehh? cleaned plenum mating surface thoroughly?
Subject Plenum pull ehh? cleaned plenum mating surface thoroughly?
Posted by CoHPhasor on March 31, 2011 at 8:55 PM
  This message has been viewed 285 times.
In Reply To surging idle posted by ste z on March 28, 2011 at 02:15 PM
Message New OEM gasket?
Made sure all your hose clamps are on?
Did your brake/clutch booster vac hoses crack?
Made sure you have the routing on your PRVR solenoid are good?
Do any deletes while you were in there?
Make sure the vac lines in general are routed properly?
Basically, the rule of thumb in troubleshooting:
If you've worked on something and now something else is broken, it's something you touched. ;-)
You need to get real specific about what you did on this pull.
