TwinTurbo.NET: Nissan 300ZX forum - Timing Belt Replacement...Write-ups or a little help
Subject Timing Belt Replacement...Write-ups or a little help
Posted by Havoc300 (Chicago) on March 30, 2011 at 7:57 PM
  This message has been viewed 173 times.
Message I am doing a water pump and thermostat replacement, so I figured to do the Timing Belt as well. The only write-up that I can find is the 60k Maintenace, which is a little bit more than just replacing the belt. I've never done this job, but figured I'd tackle it myself. So, I was hoping you guys could give the some info on just replacing the belt. What I "guess", I know, I know, but bear with me. Set Crank to TDC, mark Crank, Sprockets and Belt, loosen tensioner, remove/replace belt, release tensioner back, then finally check all marks for proper alignment. Am I at least in the ballpark or am I in the twilight zone?
Thanks Guys!
