| Subject |
please help ! tps problem |
| Posted by |
TurboZboy on March 27, 2011 at 12:45 AM |
This message has been viewed 216 times. |
| Message |
So I cannot get my tps within spec first of all.... at idle its supposed to be like .04 or something on the volt meter, and 4.0 at full throttle... I tried adjusting it a month or so ago, didnt work... got another tps... still same problem... HERE IS WHAT MY CAR DOES WHEN IM DRIVING IT: First, it idles at 2 then after a while it will drop down and die... after its warmed up it wont die when it drops down. If i stick it in gear it jumps up to 2 rpms again and it will stay there until i put it back into neutral. As annoying as that is, thats not nearly the big problem. My car is like a time bomb, in that after its been driven for a straight hour, usually on the highway, it starts shaking like crazy and when i give it gas it just jerks... This REALLY pisses me off. Basically I need to figure out why I cannot EVER get my tps within spec... There has to be a short or something in the harness... I mean i have switched out tps like 5 times so i know its not that... but its still a tps problem, so my only guess is that the harness is screwed up, but im not an expert. Car is running no codes, I NEED HELP ! what are your opinions? what do i need to do to make my Z run right?
| Follow Ups |
- please help ! tps problem - TurboZboy
00:45:34 03/27/11
Post a Followup |
