put the ebrake on and block s behind the rear wheels . The starter bolts onto the front pass side of the tranny with 2 bolts . there is one nut holding the large Hot ( 12v ) wire on the silenoid take that off and there is one connection with a single signal wire , unplug it and the starter is free . note you may need to remove the heat shield covering the silenoid to get to the power wire connections . but disconnect the battery first of all . hope that helps .
