TwinTurbo.NET: Nissan 300ZX forum - How to replace stoptech caliper pressure seals and dust
Subject How to replace stoptech caliper pressure seals and dust
Posted by sawbonez on March 26, 2011 at 10:38 AM
  This message has been viewed 1953 times.
Message boots.
After 3 seasons on the track, my front dust boots have disintegrated.
also, time to replace friction surface on my front rotors, I won't show detailed instructions on aero rotor install as the stoptech website has excellent instructions
first step after removing calipers is to remove pistons,
Use compressed air to Slowly force the pistons out. You want them to all be force out as much as possible before the seal is broken on the compressed air.
One the compressed air leaks around one pressure seal, you will have to remove the pistons with protected plires.
Place pieces of wood to prevent pistons from being forced out too far, which prevents air pressure seal loss
alternate pressurizing the inboard and outboard bleed screws on the calipers
Here, the air pressure seal has been broken so the remaining 3 pistons will not be forced out by the air, time for plires
All pistons removed, time to remove pressure seals and clean everything with brake parts cleaner
The pressure seals have a square cross section and sit in a recessed grove in the caliper. Use a pick to carefully remove the pressure seals
After cleaning calipers and pistons with brake parts cleaner, time for reassembly. Best to use brake assembly lube to lube the pressure seals
The dust boots go onto the pistons without assembly lube
Install pistons into caliper, take care not to disturb the pressure seals, no need for c-clamp just use your hands
Ensure the pistons are fully inserted to allow proper seating of the dust boot. Current dust boots are supposed to be superior to old style boots- improved longevity
Ready for a busy season on the track
Bleed the brakes. Be sure to follow brake bed-in procedure exactly per the stoptech website.
