TwinTurbo.NET: Nissan 300ZX forum - Possible fuel injectors
Subject Possible fuel injectors
Posted by Obeeone on March 21, 2011 at 10:11 AM
  This message has been viewed 127 times.
In Reply To Steady idle, but rough idle and no power. posted by Zxpress on March 20, 2011 at 04:13 PM
Message It almost sounds like a miss. It could be a dead for a couple of fuel injectors going out. You can do an easy check by disconnecting the coil to the cylinders one at a time and seeing if there is any change in the running condition of the car. If you unplug the coil and there is no change in the idle condition then you would have a possible injector or coil going bad on that particular cylinder. Just a thought though.
