| Message |
...loose in there? Assuming you're talking about the intermittent, high pitch noise, it sounds very close, not dampened by traveling through a bunch of metal. It sounds like something loose, like a washer rattling between the bolt head and whatever it's supposed to be holding down. Check brackets that bolt externally. Check the timing belt idlers, those kinds of things.
-Dan "Capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse." "Ahhh, VTEC. All of the lag, none of the turbo. It's like waiting for bad sex." "'she' also likes to swap since I think I am going to need to give her to woody again." - Dvlhntr "full alphabetic boost mode" - ChristopherTheOne "Roses are red, violets are blue, stages are gay, and so are you." - ZEngineer "Hoses as hard as Zengineer at a Hot Imports Night event" - Gizmo "Two oil eating, angry, spinning triangles of death." - turtleboy on rotary engines |
