TwinTurbo.NET: Nissan 300ZX forum - Re: knock sensor
Subject Re: knock sensor
Posted by txq45 on March 20, 2011 at 7:07 PM
  This message has been viewed 139 times.
In Reply To knock sensor posted by chalio on March 20, 2011 at 05:59 PM
Message I would not recommend replacing a knock sensor IF your not at least a minimun skill level. Try the by pass if you haven't torn a engine completely down before.
Saying that start with the procedure for removing the upper intake then the procedure for changing the timing belt then your almost to the knock sensor..Which is below the lower intake.. If that's all your going to do.. Try the By pass first.
Nistune Dealer
Built Automatics -ECU socketing ECU eprom upgrades
WWW.AAA-HiperformanceAuto.com
