TwinTurbo.NET: Nissan 300ZX forum - Rear Subframe Install
Subject Rear Subframe Install
Posted by MyDreamZ on March 19, 2011 at 1:22 PM
  This message has been viewed 241 times.
Message So I removed my subframe for powdercoating and an ES upgrade, also separating my axles from the differential so that I could coat the differential with por-15 and powdercoat the cover. I’m at the point now where I have installed everything except for the drivers side wheel hub/knuckle because nothing is lining up correctly. If I bolt the upper arms to the knuckle the A-arm won’t bolt up to the knuckle and vice versa. The problem seems to be the axle on this side sticks out too far and seems like it needs to go in more so the hub will be straight up and down. Is it possible I have the axles reversed or is the longer one on this side? Thanks for any suggestions in advance-
