TwinTurbo.NET: Nissan 300ZX forum - Check the fusible links as well as other fuses
Subject Check the fusible links as well as other fuses
Posted by CoHPhasor on March 18, 2011 at 5:20 PM
  This message has been viewed 196 times.
In Reply To Short circuit then no boost posted by hayesjc on March 18, 2011 at 04:47 PM
Message The other, even bigger problem is that you could have roasted alternator, etc.
Check for ECU codes as well.
The wastegates are controlled items and likely staying open as they're not getting the right signal.
